Also wondering why the new track records for NHMS haven't been posted yet? Usually they are posted at the same time the event results are posted.
Thanks in advance,
Greg
Greg, I was aware of the procedure. Hope to meet you up at Mt.Tremblant where, if I break the record therebetelgeuse wrote:OK Mark, thanks. I had Nate look at my car.
Sorry to hear that Paul. I should have mentioned it to you. I hope to see you at a future TT.
Greg
I plan on going to Tremblant. I thought you said you were coming to the July event at NHMS.subsonic wrote:Greg, I was aware of the procedure. Hope to meet you up at Mt.Tremblant where, if I break the record therebetelgeuse wrote:OK Mark, thanks. I had Nate look at my car.
Greg, I'll be sure to have the car looked over. Also, not to put pressure on you... I understand that Tremblant should suit your car.
I lied. It really has 650962porsche wrote:ya Greg's 450 hp bmw at tremblant will be fun !!!!!
Well... my ALFA was tech'd (by Nate) and approved ... does that mean I take the track record instead???CalypsoBean wrote:I wasn't awarded the class record for Monticello SSC as I was unaware of the inspection by a steward rule - maybe a similar thing happened? It was only my second event.
Never mind ... its THERE already for that reason...should have checked before sending this post.StephanAlfa wrote:Well... my ALFA was tech'd (by Nate) and approved ... does that mean I take the track record instead???CalypsoBean wrote:I wasn't awarded the class record for Monticello SSC as I was unaware of the inspection by a steward rule - maybe a similar thing happened? It was only my second event.![]()
yeah you were given the track record immediately following the event.StephanAlfa wrote:Well... my ALFA was tech'd (by Nate) and approved ... does that mean I take the track record instead???CalypsoBean wrote:I wasn't awarded the class record for Monticello SSC as I was unaware of the inspection by a steward rule - maybe a similar thing happened? It was only my second event.![]()
