Wanted 17" tires
Wanted 17" tires
Post by dinoracer » Mon Dec 07, 2009 10:08 pm
Dinoracer 2.0 is in the works. To get bigger brakes, it needs bigger shoes....
I've got a 17 x 9 with a 245 (on loan from Fasttrack - thanks Scott). That might be too big. I'm looking for a 225-50 or 45 17" tire - condition not important, long as it holds air - for mocking up suspension, brake and bodywork changes. If it's mounted to a 17" x 8" Mustang rim so much the better. If you've got a set of same rims, interested in those too.
Thanks Tom
McMahonRacing
Re: Wanted 17" tires
Post by McMahonRacing » Tue Dec 08, 2009 11:39 am
have a set of 17 x 8 wheels ( I think 2000 Cobra ?) if your interested, pretty close to you as well, swing by and check them out ..... Pat
Post by dinoracer » Tue Dec 08, 2009 1:47 pm
Pat-
Def interested, contact me at tjc9909 at m s n dott com with info, Thanks Tom
Post by chaos4NH » Sun Dec 13, 2009 10:49 am
Tom, I have an even dozen 225-45/17's you can have! The Grocery Getter loves to cord right fronts are NHMS. Not all are equal in width, in fact Hoosiers will rub on my left rear (wonderful smooth transition bump at Turn 10!), but a 235-45/17 RA1 does not.
Post by dinoracer » Sun Dec 13, 2009 7:54 pm
Thanks guys PMs sent on both rims and tires
Tom
