My S2000 has been making some creaking/groaning noises from the right rear. I took it to the garage on the corner, and they said "wheel bearing", which I suspected. I picked up a $90 (!) bearing assembly from Napa and brought it to them, but they mentioned that tightening the existing bearing seemed to quiet it down. I drove it around a while, and no noises.
So... Should I go ahead and let them replace the bearing?
FWIW, I might be done tracking the S2000 now that the Z is on the road...
should I get new wheel bearings?
Re: should I get new wheel bearings?
Are you taking it to the Glen? If you're gonna track it at all I would do it. ...unless the bearing does not need to be pressed in and can you 'easily' swap it yourself in the paddock.
If it's going to be 100% street I'd be tempted to leave it as is.
I don't quite understand "tightening" a bearing assembly. The bearings aren't tapered roller bearings in the rear, they're sealed bearings in a hub, right? What exactly did they tighten, the axle nut?
Dan: replace it
Replace it! You could end up like me last year when my wheel fell off.....the sad part though is that I did replace it!! It only had 54 miles on it. It is not worth risking it!
Joel Adams
1995 Pontiac Trans Am
Class T80
Class T80
- mr2sc
Been There!
When I've re-torqued a noisy wheel bearing, it 'temporarily' took up the slack/wear (quiet)...for about 1 lap.
Once there is any noise/play, thats it...finito
Also, I clean out the bearing grease that is packed into a new wheel bearing and re-pack it with higher temperature synthetic grease
Tommy
88 MR2 Mk1.5
88 MR2 Mk1.5
+1. That goes a long way in extending the life of my bearings.mr2sc wrote:Also, I clean out the bearing grease that is packed into a new wheel bearing and re-pack it with higher temperature synthetic grease
Thanks guys, new bearing installed
I knew it was the right thing to do...
But with whatever grease NSK saw fit to pack it with. It's a sealed unit, I don't think you can install different grease in it...
It's only going to see backup track duty now (hopefully) anyway...
