Miata question..
Re: Miata question..
From 1991 on, it was an option. For a few years the "M" edition had ABS standard. The first year (1990) was the only year when ABS was not available.TroyV wrote:Were Miatas ever built with ABS? If so, which years?
ST4 Miata #62
ST4 Miata #62
ABS cars have that plumbing nightmare with the pump on the pass side firewall. The washer bottle is also in the nose of the car.
It can be added, but not easily.
Some light reading on the subject.
http://www.miata.net/garage/abs/abs.htm
You ran outstanding in that Miata, Troy. The Miata ABS is not very intrusive and works well. I hardly notice it at all on my 04 Mazdaspeed Miata.One of the few cars I have left it intact on as abs usually drives me nuts.
Guess you didn't like the svt Focus?
I'm gonna stuff some 275's under my WW for the 14th.
seems like the thing to do.
Watch for undercarriage rust if you are shopping Miatas.Some people run them year round.
Thanks Mark, I had to learn how to brake in a straight line inside of two runs to get within a second of Miller (the owner). Even in a straight line it was way too easy to lock up a tire. I actually started doing the ghetto ABS tap dance to get what I wanted out of the brakes..
I wasn't crazy about the Focus at all. The tires that were on it could have been used as Corian counter top if molded to the proper shape. That and the traction control could not be shut off. I was in the stupid traction control for 75% of the run. To be honest I'd have rather had no ABS. Consequently, driving that car was like waiting for a bus for the time it took to traverse the 1.7 mile course.
It's something you get used to. In my non-ABS Miata, I used to lock up the right front pretty frequently, but I don't so much any more. In fact, in the past year as I've gotten more adept at trail braking, I find I'm braking while turning in more than ever.TroyV wrote:I had to learn how to brake in a straight line inside of two runs to get within a second of Miller (the owner). Even in a straight line it was way too easy to lock up a tire. I actually started doing the ghetto ABS tap dance to get what I wanted out of the brakes.
Call me picky, but I don't like the idea of ABS in a track car. When I ever have to go two feet in, I like knowing that my wheels are going to stay locked, and not try to keep me from skidding.
ST4 Miata #62
ST4 Miata #62
Most people remove the ABS from their Miata, never heard of anyone putting it in.
I think you may have to adjust your style a bit if you are used to ABS and just stomping on the pedal. A Miata with good pads and stock rotors will out brake most cars. It just takes a little practice. You have to ease on the brakes and gradually load them up (use milliseconds for reference).
Kooks were not helping either, they tend to lock easily.
