Hi All,
I am building a car right now and have some removed parts FS.
Car is a 1998 BMW E36 M3 4 door, white on black.
Pictures here: https://picasaweb.google.com/1073415472 ... rtsForSale
Parts FS include:
Black M interior, all of it. everything is in good shape except the rear seat which has some rips. Front seats are heated. All removed carefully. (only part I am not sure about selling is the dash top)
S52 Motor complete, in pieces, Cleaned and inspected by my machine shop. needs pistons and some head cleanup work. The motor ran but had low compression, turns out it ate a couple of spark plug electrodes at some point and scored the bores, dinged the pistons and combustion chambers. Easy rebuild and its all cleaned up already. Block was honed 5 thou over to make sure it cleaned up OK. I had intended to rebuild it but decided to put an LS motor in the car instead.
ECU and wiring harness , complete and uncut, ready for an S52 swap into something else.
Transmission and driveshaft.
Sensible offers please.
If you want the Motor built, I can do that for you.
email Haydn@motorsport-HT.com for more details, or PM me.
BMW E36 M3 Parts FS
Users browsing this forum: Ahrefs [Bot], Baidu [Spider], Google [Bot] and 1 guest
