Miata Parts
Miata Parts
Post by Stynger » Fri Nov 22, 2013 10:42 am
Apex Automotive Engineering is closing shop. :shock:
I have a crap load of Miata stuff lying around, and it all has to go.
Now is your chance to get those spares or parts you could use for your Miata's.
I have blocks, cylinder heads, trans cores, CAS, coil packs, intakes, diff's, housings, complete rear sub frame assembly, etc., etc.
If there is anything you think you could use (even little things, I'm quite the hoarder) shoot me an email and I'll check if I have it.
Prices for most stuff is at giveaway prices.
Cash only, local pick up.
lsapex at aol dot com.
Re: Miata Parts
Post by jeffw » Fri Nov 22, 2013 12:04 pm
smigiel
Re: Miata Parts
Post by smigiel » Sat Nov 23, 2013 6:37 am
Any torsen swaps? If so I'm interested
