Accusump?
Accusump?
Since I am in the process of building up my new engine, I was wondering if it would be a good idea to add an oil accumulator to avoid oil starvation. What are your thoughts on these systems? Good idea? or not needed?
Joel Adams
1995 Pontiac Trans Am
Class T80
Class T80
grovefromnh
Accusump
First and foremost for a GM engine install a baffeled road race oil pan. The Accusump system is a good addition. Don't forget an oil cooler also. Good Luck!
irondragon
I weighed the option of going with an Accusump, or a larger oil pan with good baffling, and decided to go with the larger pan.
The deciding factor was the extra plumbing/wiring. Yes, I know it's only one line but I like to keep things as simple as possible. Every line, elbow, adapter and fitting is another part with the risk of failure.
In my opinion, if you can effectively prevent starvation with baffling and a larger pan that's the way to go. That simplicity is more appealing to me than the upside of Accusump pre oiling.
my .$02
my .$02
Thanks
Thanks for all your opinions.....I have taken all into consideration and decided to get both a pan and an accusump. Placed the order an hour ago. For the price, it seems definately worth the peace of mind, especially coming off from an engine self destruction recently. Don't want to be there again.
I got a call today, and my shortblock will be ready on Friday, so i will have to go pick it up and the project will begin.
Wish me luck. Thanks again.
Joel Adams
Class T80
Class T80
