Boss frog roll bar
sparky
Boss frog roll bar
Post by sparky » Tue Mar 13, 2012 8:24 pm
Is the Boss Frog single loop accepted for COM time trials at NHMS? sparky
Re: Boss frog roll bar
Post by breakaway500 » Tue Mar 13, 2012 8:50 pm
Single hoop. Yes. Meets SCCA guidelines as well. Has a "built in" harness bar. Image
(I run a double hoop) Welcome.. 8) :sunny:
sparky
Post by sparky » Tue Mar 13, 2012 9:02 pm
Thanks breakway 500. What kind of brakes and rotors do you use. Mine is a daily driver. sparky
Post by breakaway500 » Tue Mar 13, 2012 11:21 pm
Stock "Napa" replacement rotors,...nothing exotic.Cheap disposable wear item. I like Carbotech pads for street and track.I run XP12s all around.Stop assuringly,and wear well.
Some noise..but I like that too...(reminds me to pay attention!) Run quality brake fluid and stainless hoses for best results. If your car lives mostly on the street,a pad compound more street oriented would be better..Carbotech does make a Bobcat pad that would work well. :sunny:
sparky
Post by sparky » Wed Mar 14, 2012 10:00 am
Thanks again Breakaway 500. See you at NHMS sparky
MiataSteve
Post by MiataSteve » Wed Mar 14, 2012 10:06 am
Hi sparky
Welcome to COM. There are many Miata drivers here so ask away. Do not know what your experience level is, but did you have a look here?
"Getting Started"
http://www.comscc.org/getting-started/
Users browsing this forum: Baidu [Spider], Bing [Bot] and 1 guest
