In reassembling the Miata after installing the cage, I can no longer fit the plastic trim into 2 spots in the car: the B post interior quarter panels and the under dash kick plates in the passenger and driver footwells.
The rules seem to indicate that behind the driver compartment were ok to leave the parts out. The front space is less clear.
Ruling please.
ST interior ruling
ST interior ruling
Re: ST interior ruling
Jeff, this is quote from Nate in the other thread in response to Troy:
Maybe that makes things a bit easier for you?
"nateh wrote:Troy, we changed that rule at the most recent meeting:I've had quite a few of my proposals refused. In various cases, I've come back with a rewording and had them accepted. Other folks can say the same. The process is imperfect, but it rewards persistence and persuasiveness.In all classes, interior panels, trim, and carpets may be modified or removed to the extent required to accommodate roll bars, roll cages, or other safety equipment.
Missed that, Paul. Thank you.
KKennedy717
- Fast Lapper
Nate - can you pinpoint the section number and paragraph of the rules that reference's the quote 'In all classes, interior panels, trim, and carpets may be modified or removed to the extent required to accommodate roll bars, roll cages, or other safety equipment." Thanks.
06 Mazda MX-5 #17
The 2012 rules haven't been posted yet.
It's in Section VI. F. 5.
