Car trailer for rent
grovefromnh
Open type car trailer for rent. Tows well @ VERY high speeds. $100 if you dig it out (1/2hr) $200 if I dig. Available for all COM events. Grove Marcy 603-679-5046 Epping, NH
30+ yr member
grovefromnh
Trailer specs
7000lbs capacity. trailered my 3400 Vette with no problems. Dual axle w/brakes. Use weekend before event to weekend after event. NOT for sale. Tie downs and spare tire.
30+ yr member
jeffreystrong
grovefromnh
Trailer info
I used to tow my car using a 6 cyl. auto Dodge Dakota pickup truck. Will measure bed length after this storm is over. My generator is making this bearable.
30+ yr member
dates to reserve trailer & contact info
Hi Grove,
I sent you a PM with the dates in June & July that we spoke about.
Brian
Brian
grovefromnh
Folks:
While I am attempting to contact Grove I should mention - for everyone's interest - that I will no longer need this trailer for Calabogie.
I have a tentative purchase I am working on plus I was offered the loan of an aluminum trailer from another COM member to use for Calabogie.
So Grove - if you get this message BEFORE I send you a private one - thank you for the offer and hope you can make someone esle happy.
This is indeed a good deal!
:thumbleft:
:thumbleft:
Trailer for rent
Hello Grove I just called your number but for some reason it would not go through. Anyway I am interested in renting your trailer for the Oct NHIS event if it is not yet taken. I can be reached at 978-888-57199 or at my email address sdcham@msn.com. I would like to pick it up the weekend before the event if possible.If anyone is reading this post and can get me the right number for Grove that would be much appreciated.
Thanks and Regards
Scott Chambers
Thanks and Regards
Scott Chambers
