BMW E46 Parts and 275 Tires
Posted: Fri May 06, 2022 4:38 pm
Need to clean out some unused parts. Prices are flexible for COM members, please make me an offer
Jeff
- Brey Krause R-1202 E46 Harness bar. Used for ~1 year before moving to full cage https://www.bkauto.com/R_1202_BMW_E46_S ... r-1202.htm
- VAC Aluminum floor pan kit. New, never installed https://store.vacmotorsports.com/vac-mo ... -p720.aspx
- Hard Motorsport Rear Seat Bulkhead Filler Panel. New, never installed https://www.hardmotorsport.com/hard-mot ... ler-panel/
- Bimmerworld E46 M3 Street/Track Exhaust - Diffuser Exit. Was on the car for one hour, was going to get me kicked out of my neighborhood but others live in different circumstances. https://www.bimmerworld.com/BimmerWorld ... -Exit.html
- Four Goodyear RCMD Slicks 275/35/18. These are a competitive tire with the Hoosier R7 that I used for 4 recon laps around Sebring (one heat cycle) but they are simply too wide to work on my car. Despite being a 275 tire, the carcass is 11.5" wide when mounted on a 10" wheel and these are 1/2" wider than a 275 R7 or even 275 BFG R1 . https://allianceracing.com/products/goo ... 0120290472
- One BF Goodrich R1 275/35/18 Tire, purchased new from tirerack last spring and has been in my temperature-controlled basement since. New, never mounted.
Jeff
