FS: E36 M3 Street/Track Car
TXBDan
Post by TXBDan » Tue Oct 22, 2019 3:53 pm
'97 Coupe, Alpine White on black, body/paint is in great shape. "too pretty for a track car"
135k miles
Clean title
Southern car before it came up north 5-6 years ago. It's been a fun car ever since, never driven in the winter. No rust. Enthusiast owned, extensive service and mod records. The car is primary driven to/from track days 6-8 times a year and not driven otherwise. The car has never broken down on or off track, not even a drop of fluid. It's a fantastic track car that safe, reliable, and perfectly streetable. Has cats, no CELs and passes state inspection no problem. I have datalogs with oil temp, oil pres, coolant temp logs from all recent track events.
The car needs absolutely nothing. Ready to tire and fire. My OCD and car-hypochondria is your gain!
$14,500 for everything below.
Interior:
  • Carpet, door panels, and back seats in tact. Trunk carpets are gone except floor liner.
  • Radio/speakers intact and functional
  • Sunroof delete, replaced with fiberglass panel paint-matched. 100% water proof
  • VSR roll bar fit to sunroofless car
  • Cobra Suzuka race seats (GT in driver, standard in passenger) w/ VAC floor mounts
  • Schroth Clubman 6pt harnesses passenger side (1yr old)
  • Schroth Profi 2" harnesses driver side (brand new 2019)
  • Factory 3pt seatbelts installed and functional
  • Momo steering wheel
  • A/C is deleted
Engine/Drivetrain:
  • ASC throttle body delete w/ S50 boot
  • M50 intake manifold with Turner install kit
  • 22RPD custom dyno tune, 231whp
  • head gasket replaced 2 years ago, i was paranoid about disappearing coolant. Never overheated! ARP head studs, Supertech valve springs, head checked and machined to stock-compliant specs. New valve guides and seals. Ready to drop in big cams!
  • Gripforce aluminum flywheel with organic clutch (last year)
  • UUC ssk with jaffster knob
  • Diffsonline 3.46 LSD w/ 40% static lock
  • Stromung catback exhaust (also have stock)
  • Achilles oil pan baffle
  • Oil pump nut red locktite & wired
  • oil temp, water temp, oil pressure senders installed
  • Bimmerworld HD rubber engine mounts
  • Rogue poly transmission mounts
Suspension/Chassis:
  • MCS SA shocks (last year, 8 events on them)
  • 600/700lb Hyperco springs
  • GC Race camber plates
  • Stock swaybars with poly bushings
  • E46 ZHP "yellow tag" steering rack
  • new front lower control arms (2019)
  • Poly front LCA bushings in stock lollipops
  • Reinforced stock rear lower control arms
  • OEM RTAB bushings with limiters
  • recent balljoints in rear control arms
  • recent hubs/wheel bearings front and rear
  • 75D subframe bushings
  • 95A poly diff bushings
  • OEM X-brace
  • front subframe reinforced
  • rear subframe swaybar mounts reinforced
  • RTAB pockets reinforced
  • Bimmerworld bullet wheel studs
  • Motion Motorsports under panel w/ radiator baffle
Cooling:
  • MZ3 radiator
  • Stewart Warner water pump
  • new tstat/housing
  • All hoses (inc heater core hoses) replaced with OEM
Brakes/Wheels:
  • Hawk DTC-60s front and rear (two events on them)
  • rebuilt all stock calipers last winter
  • stainless steel lines
  • 17x8.5" Kosei K1s with 245/40 Conti ExtremeContact DW. Lots of tread.
Extras:
  • 1 set of 17x8.5" Kosei K1s with 255/40 NT01s (two 50% left, two 25% left)
  • 1 set of 17x9" Apex ARC-8s with Hoosier R7s (8 cycles on them)
  • stock exhaust - good shape
  • BNIB set of Hawk DTC-60s, front and rear
  • ballast weight (plates with holes drilled in them) that fit behind passenger seat and/or in trunk
  • Turner adjustable rear control arms
  • Extra oil filters, fluids
Dan Durusky
Mazda RX8
TXBDan
Re: FS: E36 M3 Street/Track Car
Post by TXBDan » Fri Oct 25, 2019 3:58 pm
pics added. I also have a detailed spreadsheet with all mods and maintenance. I'd love to keep it in the fam!
Dan Durusky
Mazda RX8
TXBDan
Post by TXBDan » Tue Nov 05, 2019 4:58 pm
Sold! It's off to a warm happy home in Arizona.
It was a great car. :cheers:
Dan Durusky
Mazda RX8
