Miata leftover parts
Posted: Tue Jul 17, 2018 5:37 pm
1. I ended up with an extra set of Energy Suspension poly bushings and sleeves. New, unused. They fit upper control arm of NA and NB Miatas.
Again, this is just for upper control arms, not the entire front set for uppers and lowers.
$25.
2. A good non-leaking heater core with housing from a '90 Miata.
Asking $40.
3. Soft top latch in decent cosmetic condition. Works well, not loose. Passenger side.
Asking $30.
4. Stock ECU from a '90 Miata with with California emissions. the stickers are a bit hard to read but it is B61P. According to my research, it should fit any '90-92 NA.
Asking $75 or best offer.
5. 1.6 calipers in good shape, just came off the CSP NA which had excellent braking, and balance IMHO.
Also have front non-sport 1.8 calipers from an NB with 50K miles.
As these are in various shapes after sitting in the basement for a while... if anyone needs them, come get them. Small amounts of good beer are appreciated, but not at all necessary
6. Rear NA knuckles with delrin bushings. Seem to work well, the bushings are already pressed in, saving you the hassle. What you see is what you'll get. $40 a pair?
7. A radiator fan (driver's side) taken out of a parted NA. Worked fine when taken out of the car last August.
Asking $40/bo.
8. Spherical top hats. These are JiC parts, would work with any 12mm shaft shock, like Konis, Xida, etc.
Asking $140.
9. Stock diff mounts. They are fairly rusty, but could be cleaned up and painted/powder coated. Good for putting on poly bushings on your diff - you can remove rubber and prep them before install.
$10 a pair.
$25.
Asking $40.
Asking $30.
Asking $40/bo.
Asking $140.
$10 a pair.
