2016 Garage Request Procedure
brakeharder
- Rookie Driver
What is the procedure to request a specific garage at NHMS for a 2016 COM event? Completed my registration for the May 7/8 event, including a request for garage space but seemingly the only place to request a specific garage was in the comment section to the "registrar". Hopefully that is enough but just trying to see if I missed a step somewhere in the process.
Re: 2016 Garage Request Procedure
Scott Rosnick handles garage assignments. If you commented on your reg the info should be passed on. If you want to be sure send Scott an email directly. He tries to accommodate but no garuntee. Some of the garage assignments are already set so might not be available.
scott.rosnick@gmail.com
brakeharder
- Rookie Driver
Paul - thanks for the update. I will reach out to Scott to see what is possible.
Greetings all, garage assignment requests can be made in the comment section of your registration. I do review these comments and act upon them to the best of my abilities. Bear in mind, there are several factors involved in the assignments- but garage availability is assigned on a first come first served basis. In other words, sign up early for the best chance at your preferred garage. The above procedures are for NHMS and Watkins Glen. Thompson and Palmer (as of this writing) handle their garage assignments themselves.
I want a garage at Canaan
Bruce, it may be a bit expensive- but anything is possible. Might be a little tight on getting permitting and construction done.
OK. I'll bring my RV.offcamber09 wrote:Bruce, it may be a bit expensive- but anything is possible. Might be a little tight on getting permitting and construction done.
