Hoosier SM6 6 Heat Cycles
A set of 4 SM6 tires with 6 heat cycles, 2 tires are showing 2 tread lines and 2 the tread lines are just visible. All 4 have been flipped on rim 1 time already so they are evenly worn all around. They are dismounted and ready to go. Picture tomorrow when I get some time. $200 for the set
Chad Fox #9
1996 Integra GS-R T50
Re: Hoosier SM6 6 Heat Cycles
Chad, what is the tire size???
Face plant ...
205/50 15" I do have some interest in them .
but I also need suspension for my Miata as the adjustment bolts are rusted to the sleeves in the bushings and the car is as soft as a marshmallow .
so I will have to think about it some more .
but at 50 dollars each it's kind of a sore dick deal . you just can't beat it !
