Miata quick disconnect steering wheel question.
- MiataSteve
I am considering putting a quick disconnect (bolt-on) steering wheel in the Miata. The stock wheel is close to the cage, but I never had an issue. Does this look like a good set-up?
http://www.miatacage.com/steering-package-p-87.html
escortracer
Re: Miata quick disconnect steering wheel question.
Looks like your not getting any help on this one Steve. Did you get it any way?
T4 268
- MiataSteve
I got some good info from the usual sources...
I ended up ordering a NRG 2.5...its coming in next week.
http://www.getnrg.com/products/quick-re ... n-2.5/feed
I have been getting ready for a more full season of events this year. Its like Christmas every day and the UPS guy is starting to look like Santa.
I was drooling over those NRG quick disconnects awhile back. Let me know what you think about it.
Derek
#01 T??
1995 Miata
#01 T??
1995 Miata
- MiataSteve
Dtangard wrote:I was drooling over those NRG quick disconnects awhile back. Let me know what you think about it.
I used it at NHMS and I really like it. Its my first time using one so I can't compare it to other styles.
The hub is easy off and easy on! Even if the wheel was turned when its was taken off you just put the hub on and turn the wheel until it find the index and then it snaps in. No slop at all
Now if I could find an easy answer to shutting off the airbag light....other than the black tape over the light.
Tim Mahoney
- Rookie Driver
You can bridge an 8K Ohm (I think) resistor across the terminals on the orange airbag plug. I got the tip off miata.net a few years ago and it worked fine.MiataSteve wrote:Now if I could find an easy answer to shutting off the airbag light....other than the black tape over the light.
#6-SPB
To get rid of my airbag light I pulled the light and the computer from behind the dash. No buzz and no light.
Derek
#01 T??
1995 Miata
#01 T??
1995 Miata
While you're in there, drill out the pin that locks the steering wheel when the key is out of the ignition. This is a safety item.
