I have been sorting through all my junk and found a driveshaft that somebody might be able to use. It is a Mustang driveshaft and if memory serves it has been shortened and re-balanced. It measures 45 1/4" from u-joint center-center. I think this was needed either to install the Tremec trans or maybe because of the 9" diff I used to use. In any case, if you can use it speak up and I will set it aside for you. If there are no takers, it will get scrapped in a couple of weeks. It is free and located in Upton MA.
Regards,
Scott B.
Mustang Driveshaft
