1987 Nissan 300zx
Posted: Thu Sep 30, 2010 9:36 pm
				1987 Nissan 300zx built for SCCA ITS
NASCAR door bars on both sides
RH side net
19 row oil cooler w/ remote filter & t-stat
Oversized radiator – (never worry about over heating)
NISMO clutch LSD differential
Fire system
New motor in 2009
New clutch last season
Nis-Tune programmable ECU
Mechanical oil pressure, oil temp & water temp gauges
Fully adjustable rear suspension (camber & toe)
Urethane suspension bushings
Camber plates in front, coil overs at all 4 corners
16 identical 6 ½ x 15 wheels
All records & notes available
Extensive collection of spares
Annual tech current through September of 2011
This is a very reliable car, 4 mechanical DNF’s in its entire life (25 races +/-). Needs gas & set the tire pressures, otherwise is ready to go racing, leave it on the trailer between events if you like.
This season has yielded three Second places and four Third places out of seven races. $6000
Located in New Hampshire, can deliver w/in greater New England Area.
MMiskoe57 at Comcast.net
603-228-0257
http://s282.photobucket.com/albums/kk25 ... 0zx%20ITS/
RH side net
Fire system
New motor in 2009
603-228-0257
 Just a change of color will do and this would be perfect for racing.
