Will COM be considering an event at Tamworth?
Bobc
Re: Will COM be considering an event at Tamworth?
Post by Bobc » Tue Aug 23, 2016 6:48 am
Mark, the track is wide in most places with huge run off areas, Yes the last corner 15 is tough to get right it is a very tight inside radious,it works well to keep the front straight speeds down a bit and if you blow it there is a bunch of paved runnoff. I loved the 7 thru 10 it was FAST, well hell the 1-3 was fun too! We had a great time it can only get better with the curbing installed. Currently there is up to 8 inch drop off at the pavement edges once the curbs are in they are going to back fill everything.
One paved paddock is done the second much larger paddock will be paved soon after the final septic is installed so there sould be 2 good sized paddocks that are paved and power in the paddock is planed. The views are fantastic and the track is a challange, it flows very well and seamed well liked by both high and lower HP cars.
I cannot wait to go back.
