Dave's post + Chris' post + Nick's post = reason I love this place!
Hope you feel better soon Chris!
NickParlands...<chuckle>
Alex,agrabau wrote:Earlier Dan B wrote that a dyno does not measure wheel torque as you described earlier. This engineer replied to say that their machine does measure wheel torque. (which you have been denying from what I can understand) I'm sure something's getting lost in people's concept of wheel torque.
Dynapack requires the removal of the wheels and therefore maybe measures "hub torque?" Not sure.
Our dyno isn't a friction dyno either it's an eddy current retarder, magnetic.
The result of this arguing is that there is effectively no way to agree on measuring power to create rules. It's pretty clear that no one will agree.
I think something that needs to be explored and tested a bit further is the use of a GPS datalogger & corresponding PC analysis software to estimate horsepower.WillM wrote:If we are not requiring dyno plots, then this entire discussion is academic.
Likewise, if we are not requiring dyno plots, perhaps we should use a different metric than power to weight.
I have recent plots showing a range of HP from 284 on a Dyno Dynamics at Dent Sport Garage in Norwood to 308 on a Dynojet 224X at ICS in Stamford. Do you think one or all would be needed to provide data points useful in confirming the accuracy of this approach?dtlemoine wrote:Maybe a few members who have recent dyno plots could help us confirm the level of accuracy?
Hey Doug - in addition to your dyno plots, do you have a datalogger that is capable of measuring longitudinal G's? I can send you steps to build the equation over the data to see if the numbers add up.dradernh wrote:I have recent plots showing a range of HP from 284 on a Dyno Dynamics at Dent Sport Garage in Norwood to 308 on a Dynojet 224X at ICS in Stamford. Do you think one or all would be needed to provide data points useful in confirming the accuracy of this approach?dtlemoine wrote:Maybe a few members who have recent dyno plots could help us confirm the level of accuracy?
I do, so send away. In the meantime, I'll read the relevant portions of the CASC document.dtlemoine wrote:Hey Doug - in addition to your dyno plots, do you have a datalogger that is capable of measuring longitudinal G's? I can send you steps to build the equation over the data to see if the numbers add up.
If we assume the multipliers that CASC uses to be accurate (found on page 36: http://www.casc.on.ca/sites/default/fil ... es_net.pdf) the DSG dyno gives you 356.8 at the wheels, and ICS gives 360.2. Those numbers are very close (less than 1%) and I think could go a long way in helping us "equalize" results from different dynos.
If we could take it a step further to compare to the data logger's results, we might have a good first data point to help the cause.
I looked over the CASC calculation & came up with the following using four of my car's dyno sessions.dtlemoine wrote:If we assume the multipliers that CASC uses to be accurate (found on page 36: http://www.casc.on.ca/sites/default/fil ... es_net.pdf) the DSG dyno gives you 356.8 at the wheels, and ICS gives 360.2. Those numbers are very close (less than 1%) and I think could go a long way in helping us "equalize" results from different dynos.
