Car Porn
Re: Car Porn
Post by 6PAK72 » Sat Aug 29, 2009 9:07 am
[quote="breakaway500"]Glad to hear you got the TR sorted and those times are falling! :wink:
You ran with NEQ at WG earlier this week? So did I.. I saw Jeff,but did not see the TR-6. Where were you hiding?
Did you see the Ferrari 430 and the Lambo Gallardo?
You were being anti-social out in the outer parking lot. We were in #22 garage learning all sorts of things about running Miata.
Good we were in the garage - last run of Monday we started to feel a rumble from the pass. floor. Brought it in and wobbled stuff around, and lots of people helped diagnose that I had a loose lower control-arm bolt. While doing that, we discovered a nearly-shot hub, and Jeff had one in his new truck. So, we changed a hub in 20 minutes and went out again.
Liz was second-seat with Jeff when you blew them off going into the esses - Jeff loves the turbo!!
I think I might sign up for the Sept. NHIS run - will you be there?
Re: Car Porn
Post by breakaway500 » Sat Aug 29, 2009 9:12 am
We weren't being anti-social..we were robbing elecricity...that is till the Volt Nazis bagged us.. :oops:
Ah,you had the Miata.That explains not seeing the TR.
I love my turbo too! :wink: I'll be turning the boost up a bit once I get better brakes... :shock:
Sept. NHMS is a go..if it's :sunny: I'll take the Atom. If not, The MSM.
Re: Car Porn
Post by 6PAK72 » Sat Aug 29, 2009 9:51 pm
Achtung, Nicht Ein Voltage!
Vamoose, Schnell! :twisted:
I watched your laps from the top of the hill at the esses, reading your line through there. Funny, you take the "power" line rather than the "momentum" line...
Hope to see you 9/24.
Re: Car Porn
Post by breakaway500 » Sat Aug 29, 2009 10:03 pm
Funny?I don't think so...works well for me. Strange,maybe. It's a 230whp "heavy" street Miata...so I have to improvise...occasionally. :wink: Improvise.Adapt. Run watcha brung!
I saw a TR-7 (that had a TR-8 motor in it) for sale,today. Made me laugh. Those were ugly times. Remember that commercial?
"The shape of things that win" and the TR-7 would drive into a triangular 1 car garage...
horizenjob
Re: Car Porn
Post by horizenjob » Sat Sep 12, 2009 10:08 pm
Is it possible to add more bolts? Or to add steel pins? I think they do that for Cosworth BD type engines etc. It is probably rather painfully expensive, not something you would do with a hand drill, LOL.
Flywheel bolts and run lines
Post by 6PAK72 » Sun Sep 13, 2009 9:46 am
So Yes, it's possible to add bolts. A number of TR racers have added 4 more but it looks awfully tight on the crank end with all those holes in it!! I really did not want to drop the crank, and you need a line-bore tool to do this properly.
We finished the work - there was one snapped bolt - it was split right at the shoulder of the head. It appears that the guy who did the engine 4 years ago re-installed the existing factory OEM bolts - not even replacements! - because the bolt heads still had the British markings on them - BS for "British Standard" the way we used to have "SAE" for Society of Automotive Engineers.
We used that Fidanza flywheel, a LUK Porsche aluminum clutch, the constant-velocity throwout bearing, and held it all together with ARP hardware. I weighed what we put into it in new parts - 24.5 pounds. What came out weighed 49 pounds! Heel-toe will be troublesome for a while.
So the shifting is like cream cheese! it's smooth and precise in a way I've never experienced the TR. Also, it's no longer 35 pounds of pressure!
BUT that did not eliminate the vibration, so we're back at it. The only part of the drivetrain we have not replaced in the rebuild is the diff. It's the 1972 factory box. Since the vibration is MPH-associated rather than RPM-associated, I've torn down the entire drive train looking for the culprit. All the U-joints are new and were fine, the suspension is locked correctly, the IRS axle bearings are fine, no run out, etc.
This weekend we are installing a Nissan 200-unit diff, same gearing 3:69. Dick Good (great TR racer and parts guy) makes a beautiful kit http://www.goodparts.com/shop/index.php?categoryID=16
I hate being in the "throw parts at it" mode.
Tom, I didn't realize your Miata has 230hp! No wonder you were on the "power" line!! That thing must fly!
Re: Car Porn
Post by breakaway500 » Sun Sep 13, 2009 2:47 pm
"Tom, I didn't realize your Miata has 230hp! No wonder you were on the "power" line!! That thing must fly!"
Oh,it's Ok. :wink: I'm still getting used to it, and turning the boost up a bit every outing...
Double check the balance on your driveshaft. Many times I have chased vibrations to this component.Doesn't take much to upset it.
MARK (kind of like TOM,only sideways..sort of.. :D )
Re: Car Porn
Post by 6PAK72 » Tue Sep 15, 2009 12:35 pm
I realized that Tom is Mrk sideways about the time I hit the post button. So, next time I see you sideways, I'll call you Tom. You can call me idiot!
Re: Car Porn
Post by breakaway500 » Tue Sep 15, 2009 12:54 pm
Idiot? Never...forgetful..possibly.. :wink:
Users browsing this forum: Bing [Bot], Google [Bot], Semrush [Bot] and 1 guest
