Shortening a coilover coil spring
Re: Shortening a coilover coil spring
Post by Stynger » Mon Aug 17, 2009 1:48 pm
breakaway500 wrote:I have a bunch of 225/50/15" BFG-R1's on TD 38mm offset wheels I need to use up (Atom rejects) and they just clear the front fender lip at 12.5",so I'm shooting for that as my ride height.
I'm running 1.5 neg camber all around,with just the lower control arm cams doing the adjusting.
Any lower than 12.5" and I have to jack the car up to get it on my lift. :lol:
Well, there's your problem..... :shock:
With a zillion Miata's out there, you have to blaze a new trail?
Roll the fenders, drop the car, neg 2.5 - 3.0 front camber, neg 2.0 - 2.5 rear camber, zero toe front and rear.
That ought to get you out of the 25's :D
FWIW I have to jack all my cars up to get them on my lift. :D
