Cooling system options
Re: Cooling system options
Post by eastcoastbumps » Sun Jan 25, 2009 3:41 pm
You may also want to remove the rubber seal at the back of your hood. You can also try securing the hood with longer bolts and washers to increase the airflow out of the engine bay.
Post by TroyV » Mon Jan 26, 2009 11:03 am
I usually pull that seal out. I like your idea about using spacers to prop the back of the hood up a little.
Post by Stynger » Mon Jan 26, 2009 6:22 pm
TroyV wrote:I usually pull that seal out. I like your idea about using spacers to prop the back of the hood up a little.
That usually will turn into a high pressure area, think cowl induction. You could be pushing air under the hood, not out.
Post by CP » Sat Jan 31, 2009 12:07 am
Sort of on-topic: Redline Water Wetter versus the Royal Purple coolant additive? Is there a preference? The Redline is obviously easier to get (Autozone) so I'm guessing that most have experience with that...
