What is the sealing tape everybody is using to seal off the back of the car (fuel tank) from the drivers compartment? Where can I get it?
Thanks, Steve
Sealing tape used on Miata bulkhead
- MiataSteve
The aluminum HVAC stuff you can get from Home Depot. Comes in rolls with a backing. Cut to size, peel off backing, stick on.
I think it is called "dead soft aluminum tape". Also known as aluminum foil tape, aluminum tape, etc.
If you are going to pass SCCA inspection, the tape used to cover the holes should meet their rule of thumb, which I think is the 3x rule. If you are covering a 1" diameter hole, the patch (tape) should be 3" in diameter.
For the package shelf, tech may use a flashlight to look for visable light poking into the trunk. Finally, if this is for an SCCA tech, you have to seal up the holes in the firewall, again, following the 3x rule.
- MiataSteve
Users browsing this forum: Ahrefs [Bot], Baidu [Spider], Bing [Bot] and 1 guest
