I WILL SHIP!
I was almost ready to start building a track car, when plans changed.
Prices are FIRM.
CASH ONLY.
I WILL SHIP but you will have to pay shipping and paypal fee (or no fee if using friends/family)
These parts are BRAND NEW.
I will try to get as many pictures as I can but I have a lot of parts. I would google items you are interested in.
Items are located in Beverly MA.
These Parts were bought for a 95 M3 with Bilstein PSS9 coilovers. They may fit other models and years but please do your research.
GC Roll center correction kit (95 M3 only) $350
GC Swaybars Set Medium Front & Small Rear $550
BW TrackCAB Solid control arm mounts $120
BW Track engine mounts $160
Magnetic oil drain plug $4
Powerflex diff mount set 95A $100
Chase bay clutch line $45
Tiny ADS serial cable $35
3.46 LSD 40% lock (6 bolt) $1000 built by serg1359
VAC upper inner control arm bushing $110
VAC Fuel starvation kit (OBDI 95 or earlier) $265
HARD Motorsport dash block off kit $35
HARD Matte Black Suede Air Assist Dash kit $105
HARD firewall block off plate $33
Rally Road Extreme Duty Trans Brace $110
Mishimoto fan shroud kit $180
Aluminum door panels (look white in photo but they are kind of a brushed aluminum) $150
(10) TMS wheel studs 74.5mm $75
(10) TMS wheel studs 85.5mm $75
Custom Triple 52mm Gauge Pod Center Vent (able to still use radio) $85
(2) Takata 72000US-H2 6 point harness (Real Takata Not FAKE) $300 each $525 for both
Momo Mod 78 330mm Black Suede Steering Wheel $180
PSS9 linear conversion kit (4 springs and camber plates). $600
(2) Swift 60mm 13kg 728 lb 5" rear springs
(2) Swift 60mm 11kg 616 lb 6" front springs
(2) GC Camber Caster RACE plates for 60mm springs and PSS9 shaft/nut
SOLD ITEMS
Complete S54 dual pickup Oil pump swap. Pretty much everything you need. New pan, gaskets, nuts, bolts, oil pump, pickup tubes, etc. Pump was from a 40k e46 M3. $700
AKG DTM shift rod $100
Mishimoto coolant Aluminum Expansion Tank $100
HARD heater core coolant plate $18
m50 drilled oil pump nut $5
ZHP steering rack (used VERY good condition) $180
Left and Right Lemforder tie-rods with locking plates $70 for pair
Miller WAR chip (for Bosch ECU with last 3 digits 413) $280
Mishimoto E36 X-line Radiator $400
BW silicone coolant hose kit $55
BMW Euro oil cooler kit (cooler, lines, and Euro Housing $550
UUC Underdrive Pulley set $150
3.5" HFM Bosch MAF 0280217800 (540i)(for OBDI cars) $100
HARD brake cooling M3 oem size $275
(2) Red Bride Vios III seat (Real) $750 each $1350 for both
S2R Fiberglass Sunroof delete panel $200
BW trailing arm bearing kit $120
Raceland header $115
Rally Road Oil Pressure/Temp Gauge Adaptor Block $50
Chase bays vanos oil line $50
CAE shifter silver with blue knob $880
BW Premium street/track rear lower control arms $265
BimmerWorld E36 M3 Race Exhaust by MagnaFlow $750
Rogue Tran Mount $40
AFE cold air intake Euro HFM $180
AKG Trailing Arm Plates $15
BW Silicone Throttle Body Boot for Euro HFM $45
BW euro oil filter banjo bolt $15
HARD front splitter support brackets $105
Jack pad ext adapter $30
Stewart Water Pump $100
Chase bay power steering cooler kit $340
(2) VAC lap belt mounting kit $20 each
(2) VAC anti sub bracket $20 each
VAC Seat mounts Driver $140
VAC Seat mounts Passenger $140
VAC extinguisher mount $55
Rogue Diff Cover $480
24lb blue Injectors (used VERY clean) $50
BW Front solid brake guide kit $40
BW Front titanium stock M3 brake barrier plates $40
(2) BMW Front wheel bearings $110 for pair
(2) BMW Rear wheel bearings $50 for pair
IE Billet Throttle Cable Bushings $20
AKG Brake Pedal Delrin bushing set $9
AKG Clutch Bronze bushing set $10
TMS rear subframe Bushings Solid Race $145
(4) Lemforder ball Joints 33306852895 $65 for all 4
Rear Subframe bolt set $10
Items I decided to keep and put on my M3
MaxVelocity E36 M3 RS Lip Spoiler $200
BMW OE Front Subframe bolt set $10
AKG Front Subframe Reinforcement Plates $10
AKG Rear Sway Bar Reinforcement Plates $10
Turner 10mm wheel spacer $80
Ireland Motorsports Stainless Steel Front Brace $180
RS Red door pull straps $110
MKAH Black Diamond plate floor pan set $280
(4) D-force flat black 17x9 wheels $900
Replica GT rear wing with extension spacers (came with a slight crack, easy repair before paint) $180
Replica KEY'S Racing Leather 350mm $50
BW clutch stop $10
Ground Control Rear Articulating Spring Perches $190 (ON HOLD)
Performance Thermostat (75 deg. C) - 11 531713040 $10 (ON HOLD)
Fuel Pressure Regulator Plug - M50, M52, S50, and S52 $12 (ON HOLD)
