Post
by DanB » Wed Oct 31, 2012 12:39 pm
Not bad! Still slower than the 240Z around NHMS, though! Not to mention Will's and Gordon's Miatae
Hopefully having real tires and functioning power steering will help out next year...
jadams
Post
by jadams » Wed Oct 31, 2012 12:47 pm
Did that painters tape stay on at 185 mph?
Joel Adams
1995 Pontiac Trans Am
Class T80
- Administrator
Post
by TroyV » Wed Oct 31, 2012 1:06 pm
...and how did the car feel at that speed?
Post
by DanB » Wed Oct 31, 2012 1:17 pm
Picture was taken just after the run. Blue 3M painter's tape stayed on. However, a wad of the Dollar General Store cheap-o masking tape (off-white) I had used on Saturday did come off at 150mph. Then the same stuff refused to budge when I de-taped the car, leaving tape and goop remnants all over! Whereas the blue 3M stuff came off without issue.
ONLY use good stuff!
The car did not feel terribly stable at speed. The back end was moving around some, I had to steer it to stay straight. A bit disconcerting at 180+. Hopefully a front undertray and rear diffuser will help in that regard, I don't really want to spoiler or wing it. Maybe I'll add vertical fins a la 1957 Cadillac or 917...
Post
by breakaway500 » Wed Oct 31, 2012 2:41 pm
Very impressive,Dan! For a stock aero body designed 20 years ago, that is damn impressive. You must have some stout HP under the hood...
Post
by Stynger » Wed Oct 31, 2012 3:53 pm
Wow! That's great Dan. Try doing that with a Miata?
Post
by brucesallen » Thu Nov 01, 2012 12:22 pm
the '94 R2 (that I had and is now my Lotary 7) had a rear wing. You didn't want the drag?
Post
by DanB » Thu Nov 01, 2012 1:11 pm
brucesallen wrote:the '94 R2 (that I had and is now my Lotary 7) had a rear wing. You didn't want the drag?
Zackly, an increase in Cd of even 0.01 would result in a 1mph lower speed! And I like the pseudo-sleeper clean look
Mine is a '94 base model, so it didn't come with a sunroof (yay!) or rear wing.
Obviously for track work, it could use a serious rear wing, but it is primarily a street car and I'll probably never put a big wing on it. If I do the Texas mile or similar event again, I might consider a modest wing, something like the FD "Bathurst" one. Would be interesting to try a wing with and without the main element (i.e. try it with just the supports acting as vertical fins).
Post
by brucesallen » Fri Nov 02, 2012 1:02 pm
what have you done to the engine? two years ago I canned the twin turbos and had DentSport do a great single Garrett ball bearing turbo and fine manifold.
Post
by DanB » Fri Nov 02, 2012 1:17 pm
brucesallen wrote:what have you done to the engine? two years ago I canned the twin turbos and had DentSport do a great single Garrett ball bearing turbo and fine manifold.
No turbo(s). No rotors, either
It's an LS2, with L92 heads, LS3 intake, mild cam. There was a freshly built turbo rotary FD at the event, but by the time I got there Friday afternoon, it had already expired!
Resolution78
- Fast Lapper
Post
by Resolution78 » Fri Nov 02, 2012 8:14 pm
what safety stuff were you required to have.... main reason i dont bring the boss to something like this is i dont want a cage in it......
its is my daily driver alllllll summer
and 184....awesome..... i have never been that fast on 4 wheels yet
Post
by DanB » Fri Nov 02, 2012 10:57 pm
Below 190mph, no roll bar/cage required (except for convertibles).
Even at 190+, 4-point roll bar and 5- or 6-point harness is all that's required. Full 8-pt cage is required at 215+
Rules/regs are available at the website:
http://www.texasmile.net/rulesregulations.php
- Administrator
Post
by WillM » Sat Nov 03, 2012 1:41 pm
Holy S Dan, that is awesome! Time for a rollbar though, eh?
Second improvement, after the bar, in-car camera.
