I don't remember a bump in T2. I do know that the car seems to squirm if you have a tire running down the seam in the pavement near the bottom of the hill in T2.dradernh wrote: In response to a question, Mario also said he didn't notice any bump in T2. My recollection is that there's a bump just over the crest of T2 that, if you're fiddling with your line as you cross over it at speed, might well make for a very exciting end to your day.
Pucker up! We're going to MOSPORT!
Re: Pucker up! We're going to MOSPORT!
- mr2sc
It's more of a slight 'yump' around the 1st apex. Depends on the car, and the actual line through the turn but not that big a deal.
What 'is' nice however is how they've repaved T10. It's nice and smooth and no longer has the rough transition onto concrete
Tommy
88 MR2 Mk1.5
88 MR2 Mk1.5
mr2sc wrote:It's more of a slight 'yump' around the 1st apex. Depends on the car, and the actual line through the turn but not that big a deal.
Hi Tommy:
You bring some interest news to ... (me?). T-10 was always "tricky" because of the rough pavement, need to come fast onto the straight, decreasing radius (a bit) to the straight and winding up always in that little piece of pavement when tracking out than always provided "hairy" moments. So what exactly have they done there?
Did these improments made the tack faster or just "safer" to negotiate that turn?
Next question: planning on going? Never mind, I saw you on the roster!
- mr2sc
Hi Stephan,
They've paved over the first part only (till before the apex), eliminating the impact caused by hitting the concrete. It’s much kinder to the car. They’ve also added some small asphalt patches outside the exit kerbing at T10, as well as T1 (particularly welcome there, as the asphalt depression at track-out can be a bit unsettling)
So, “is it safer?” I suppose the answer 'can be' yes. I’ve seen more than one car go wide in these spots and then get turned across the track into the inside wall.
But, if you now start regularly using the little asphalt patches as part of your line and tracking out onto them, then I suppose not.
In my case, I now feel comfortable using the kerbing at T10, but still try to stay off it at T1.
Overall, when I was there, grip level seemed lower than usual (after a race weekend), but besides the nice new entrance tunnel the only noteworthy additions are new pedestrian bridges over the top of T2 (turn in for me) and the top of the back straight (lift-off for me). So, these new, very obvious reference points can be helpful I suppose.
Here are a few 'pace laps' (by COM standards) from 2 weeks ago http://www.youtube.com/watch?v=-SC3aiK08jk&feature=plcp
Looking forward to seeing y’all again
Tommy
88 MR2 Mk1.5
88 MR2 Mk1.5
Tommy,
No long shirts for you!
Those Porsches should move over for you. Is it mandatory to have terrible lines if you drive a Porsche? And where they brake!
- blindsidefive0
- Moderator
No.brucesallen wrote:Is it mandatory to have terrible lines if you drive a Porsche?
...although a good body of evidence would suggest: "yes"
- mr2sc
well, as long as its 'their' lines and braking that are terrible, I guess I'm kinda okbrucesallen wrote:Tommy,
BTW, I just watched it again and around 6:05 can see the Mustang ahead of me bobble over the little dip/yump/bump in T2 that that was mentioned earlier. Its really nothing much, at my pace anyway
Tommy
88 MR2 Mk1.5
88 MR2 Mk1.5
are garage spots available at mosport?
rebecca
rebecca
Mosport has no garages.n1gzd wrote:are garage spots available at mosport?
rebecca
- blindsidefive0
- Moderator
Is anyone carpooling from Boston area? The fellow crack...err, track...addicts I usually run with won't be coming, so ideally I'd like to pair up with some other folks for the long drive. Otherwise...
Also, where is everyone staying? Anyone need a roommate? Last year I think I stayed at the Holiday Inn Clarington/Bowmanville and it was pretty nice, but I'm open for anything.
Hi Nick:blindsidefive0 wrote:Is anyone carpooling from Boston area? The fellow crack...err, track...addicts I usually run with won't be coming, so ideally I'd like to pair up with some other folks for the long drive. Otherwise...
1) Pooling: Depending if you are driving or towing - I am driving, could hook up by a spot on the Mass Pike;
2) Pooling: also depends if I go a day earlier and break the trip in half by stopping over in Montreal to visit friends
3) Hotel: I was thinking about camp or hotel. Both have pros and cons (rain on one hand, extra gear in car, having to get gas) but I am game on sharing a room if I can arrange a ride to the hotel so I dont have to swap tires). And yes, I believe many will stay at the HI-Express which is better.
Let me know via pm but send me details on your travel dates and plans.
Does mosport have showers?
Rebecca
Rebecca
yes. Good.n1gzd wrote:Does mosport have showers?
Rebecca
^ Beware..they also have a "bad" shower. Back in '08 I was directed to the infield shower stalls. Not fit for a horse! First time in memory I decided not to take a shower after a long day. I found the good showers in the morning..
(my pre truck camper days..
Mark, the showers are great ... not sure which one you used but you need to go on the infield and PASS the karting track then go UP the hill near the flagger post of T-2/3. Hot water, wide stalls, benches, good lighitng, etc.breakaway500 wrote:^ Beware..they also have a "bad" shower. Back in '08 I was directed to the infield shower stalls. Not fit for a horse! First time in memory I decided not to take a shower after a long day. I found the good showers in the morning..(my pre truck camper days..
