Miata quick disconnect steering wheel question.
MiataSteve
Post by MiataSteve » Tue Feb 08, 2011 2:50 pm
I am considering putting a quick disconnect (bolt-on) steering wheel in the Miata. The stock wheel is close to the cage, but I never had an issue. Does this look like a good set-up?
http://www.miatacage.com/steering-package-p-87.html
escortracer
Re: Miata quick disconnect steering wheel question.
Post by escortracer » Fri Feb 25, 2011 6:20 pm
Looks like your not getting any help on this one Steve. Did you get it any way?
T4 268
MiataSteve
Post by MiataSteve » Fri Feb 25, 2011 8:14 pm
I got some good info from the usual sources... :wink: I ended up ordering a NRG 2.5...its coming in next week.
http://www.getnrg.com/products/quick-re ... n-2.5/feed
I have been getting ready for a more full season of events this year. Its like Christmas every day and the UPS guy is starting to look like Santa.
Dtangard
Post by Dtangard » Fri Feb 25, 2011 8:42 pm
I was drooling over those NRG quick disconnects awhile back. Let me know what you think about it.
#01 T??
MiataSteve
Post by MiataSteve » Wed Apr 27, 2011 8:49 pm
Dtangard wrote:I was drooling over those NRG quick disconnects awhile back. Let me know what you think about it.
I used it at NHMS and I really like it. Its my first time using one so I can't compare it to other styles.
The hub is easy off and easy on! Even if the wheel was turned when its was taken off you just put the hub on and turn the wheel until it find the index and then it snaps in. No slop at all
Now if I could find an easy answer to shutting off the airbag light....other than the black tape over the light. :roll:
Tim Mahoney
Post by Tim Mahoney » Thu Apr 28, 2011 9:43 am
MiataSteve wrote:Now if I could find an easy answer to shutting off the airbag light....other than the black tape over the light. :roll:
You can bridge an 8K Ohm (I think) resistor across the terminals on the orange airbag plug. I got the tip off miata.net a few years ago and it worked fine.
#6-SPB
Dtangard
Post by Dtangard » Thu Apr 28, 2011 9:57 am
To get rid of my airbag light I pulled the light and the computer from behind the dash. No buzz and no light.
#01 T??
nateh
Post by nateh » Thu Apr 28, 2011 10:07 am
While you're in there, drill out the pin that locks the steering wheel when the key is out of the ignition. This is a safety item.
