help me find a car
Re: help me find a car
Post by chaos4NH » Thu May 13, 2010 7:19 pm
geoffm wrote:for a ride around i would need a helmit and long sleeve shirt and jeans ? i do have arm restrants if needed
Yep M or SA 2000 or newer helmet. We are at NHMS om May 31 and June 1. Signup at the registration link on the first page of the website. Thanks for your interest in COM!
geoffm
Post by geoffm » Fri May 14, 2010 6:30 pm
neack brace? and i just regesterd for a ride along
Post by 962porsche » Fri May 14, 2010 8:47 pm
head and neck restraint is not a requirement with comscc yet . but its a good idea to have one . just a helmet if you have one long sleeves shirt and pants with closed shoes . come up hang out and talk with alot of people . out of all the clubs i run with the people in comscc are by far the best . from day one i run with comscc the other drivers were all very frendly .
Post by Mark Swinehart » Fri May 14, 2010 9:16 pm
Some of us actually know how to spell too!!!
Post by 962porsche » Fri May 14, 2010 9:47 pm
NOT ME ! and i'm damb proud of it ! i have a thing with my eyes ! its called dyslexia . i see word and numbers back wards . some people can get glasses to fix there eyes but there are no glasses that can fix the eyes of a person with dyslexia . the good thing about it is must people with it have an above average IQ . you know ? like albert einstein he was one .
Post by brucesallen » Sat May 15, 2010 3:23 pm
geoffm wrote:yea plus i like the fact that ide have a roof over my head as far as headers would go i probably make my own instead of spending 400 bucks on them.then make my own exhaust and short ram intake.then would be the brake issues dot 5 brake fluid brake coolers with blowers and some good race pads like the yellow stuff pads
DOT 5 is not for racing. Motul 600 DOT 4
Post by 962porsche » Sat May 15, 2010 10:34 pm
yep . a little info about silicone (dot 5) brake fluid . it does have a higher temp rating that is why there is a misconception about it being a racing brake fluid . dot 3's and 4's known as glycol fluids have many more benefits over silicone fluids . silicone fluid will aerate very ez it does not disperses or accept moisture making your brake system more prone to corrosion . giving you even more maintensnce . becouse there are no naturally occuring lubricity its not o-ring and seal friendly as a dot 3 and 4 is .
geoffm
Post by geoffm » Mon May 17, 2010 2:32 pm
i did do some research on this and u guys are right dot 4 is the way to go for racing.dot 5 is only recommended for show cars due to it not eating paint if spilled.but dot 5 is better for o rings and seals because its silicone is a natural lubricant.if u do get water in the system it goes to the lowest point because its heaver than the silicone making it hard to get out i got this info from brembo and willwoods website
geoffm
Post by geoffm » Mon May 17, 2010 2:37 pm
willwood
The Department of Transportation specifies three common types of brake fluid DOT 3, DOT 4 and DOT 5. DOTS 3 or 4 are the preferred types for high performance, high temperature use and are available in a very wide range of formulations and performance characteristics. DOT 3 fluids are usually less expensive than DOT 4 fluids and are less capable in extreme use. DOT 5 is a silicon based fluid which is not good for high temperature use (it expands, becomes compressible, and makes your pedal soft and spongy) DOT 5 is inert and not corrosive which makes it good for preserving classic cars because it doesn’t take you paint off in the event of accidental spillage or leak.
Wilwood has versions of each DOT fluid engineered to the specific needs of our customers. Wilwood Hi- Temp is the maximum performance DOT 3 fluid at cost effective price. Wilwood EXP DOT 4 fluid is the highest temperature, highest performance, lowest compressibility brake fluid you can buy. Our DOT 5 fluid is formulated to protect your classic vehicle and give reliable brake performance.
Post by 962porsche » Mon May 17, 2010 6:50 pm
silicone is not a natural lubricant ! if it was you would be using it to remove bolts and not wd40 (water displacement 40 ). do not confuse silicone with syntheic they are not the same . dot 3-4 glycol is a natural lubricant . that is why it is used on abs systems ! it will not harm the seals and o-rings in the abs system as a silicone will .
MiataSteve
Post by MiataSteve » Mon May 17, 2010 8:24 pm
Post by eastcoastbumps » Wed May 19, 2010 4:15 pm
Might be a bit over budget after its all said and done, but a good deal none the less. Looks like it would be right up your alley.
http://www.ls1tech.com/forums/vehicle-c ... 500-a.html
