Masking Tape for Numbers?
pardsbane
Post by pardsbane » Wed Oct 28, 2009 5:08 pm
Is it ok if I use a contrasting color masking tape for my door numbers?
This Saturday will be my first event.
cuda6666
Re: Masking Tape for Numbers?
Post by cuda6666 » Wed Oct 28, 2009 5:12 pm
Anything you want. The uglier the better as long as the timers can read the numbers. Also, if you're running water/meth injection, be sure to tape a big warning sign on the side of your car :P
Post by Mark Swinehart » Wed Oct 28, 2009 5:27 pm
"Car numbers and class must be placed on both sides of the car before Tech Inspection. Numbers must have a minimum height of eight (8) inches. Class designations must have a minimum height of 4 inches. Numbers and class designation shall be on a vertical side panels or vertical side windows and shall be of contrasting color to the car. ALL MARKINGS MUST BE EASILY READABLE BY CORNER WORKERS. Novice drivers will place three vertical stripes on each rear quarter panel and trunk lid. Magnetic numbers are permissible provided they are secure to the vehicle, which is the responsibility of the driver of the vehicle."
Neptune441
Post by Neptune441 » Wed Oct 28, 2009 8:59 pm
cuda6666 wrote:Anything you want. The uglier the better as long as the timers can read the numbers. Also, if you're running water/meth injection, be sure to tape a big warning sign on the side of your car :P
lol Youre bad!
Adrian
cuda6666
Post by cuda6666 » Wed Oct 28, 2009 9:48 pm
Thanks for noticing :twisted:
pardsbane
Post by pardsbane » Thu Oct 29, 2009 10:44 am
Another newbie question: Does a leaking head-gasket count as 'water injection'?
Post by jlwhorf » Thu Oct 29, 2009 11:15 am
cuda6666 wrote: Also, if you're running water/meth injection, be sure to tape a big warning sign on the side of your car :P
Controlling/forbidding methanol has not yet gone in the rule book. If any of you want to run your alcohol burners, now is the time to do it.
cuda6666
Post by cuda6666 » Thu Oct 29, 2009 11:16 am
Depends on whether the smoke is coming from your tail pipe or off the exhaust manifold. In the latter case, it would be considered water ejection.
Post by brucesallen » Thu Oct 29, 2009 1:02 pm
pardsbane wrote:Is it ok if I use a contrasting color masking tape for my door numbers?
Very Declasse.
Get Contac paper and cut out something better.
RyanC
Post by RyanC » Thu Oct 29, 2009 3:54 pm
Very Declasse.
Ahoy polloi!
What's wrong with masking tape, Bruce? Looks great here:
next thing you know, we'll be hearing you shout "You kids, get off my lawn!" :lol:
Post by brucesallen » Fri Oct 30, 2009 11:29 am
You Whippersnappers!!
