Yes, see my earlier post. Arm restraints should be allowed in Prepared when window nets are not practical - like in hardtop street cars with roll bars but no cages. Not that I have a dog in this fightDanDarcy wrote:The purpose of the net is to hold your arms in in a roll over. The purpose of arm restraints is to hold your arms in in a roll over. They both do the same jobPersonally I would leave it up to the driver as to which they want to use
Did you submit a rules change for that ?
Window nets and PB
Re: Window nets and PB
For the sake of clarity, seems like the words "when window nets are not practical" could be stricken without changing the rule proposal.cuda6666 wrote:Yes, see my earlier post. Arm restraints should be allowed in Prepared when window nets are not practical - like in hardtop street cars with roll bars but no cages. Not that I have a dog in this fightDanDarcy wrote:The purpose of the net is to hold your arms in in a roll over. The purpose of arm restraints is to hold your arms in in a roll over. They both do the same jobPersonally I would leave it up to the driver as to which they want to use
I will be running in the PB class and I know i have to have a window net for the driver's side. Since this is the first time I will be running with COM, I need to have a passanger side seat for the instructor with the same safety harness as mine so I can obtain the COM license.
My question is, do I need to buy and install a window net also for the passanger side too?
Your instructor could optionally use arm restraints. Maybe you can borrow a set for the day.
Do you know if most people at the event will have something like that I can borrow or do I have to provide that for the instructors?Mick wrote:Your instructor could optionally use arm restraints. Maybe you can borrow a set for the day.
I'm trying to not to spend money on something that will only be use for very short time so I can get my COM licenses and not use it anymore possibily.
I bet you would have no problem finding a set to borrow. Almost guaranteed. You may want to post up a new thread and see if you can connect with someone who has a set. That way it'll be one less thing to worry about on the track day.
I have a set of arm restraints that you can borrow - come see me before tech - I will be in garage 4,5 or 6 - red Miata #49
Bill Hosselbarth
COM Secretary 2011
1994 Mazda Miata
#49 PC
COM Secretary 2011
1994 Mazda Miata
#49 PC
Thank you. This is for the Watkins Glen event if you are going to be there. I'll look for you.bhoss wrote:I have a set of arm restraints that you can borrow - come see me before tech - I will be in garage 4,5 or 6 - red Miata #49
