Hi,
I registered as SSC but according to the rules I should be SSB. I hope that it will be easy to just change that at registration.
I have discovered that I registered my car in the wrong clas
Re: I have discovered that I registered my car in the wrong clas
Yes, just tell Mark when you register and he can take care of it.
Better yet, e-mail him now and maybe he'll have time to change it beforehand: COMRegistrar@comcast.net
Also double-check when you check-in at the gate at NHMS. You will be given a TECH Sheet and in there make sure the car is in the right class. If not, make you you write it over in PEN and sumbit to the tech inspector.
HTH.
HTH.
Hi Rebecca. Technically...your Saab turbo should be in ST3,due to the custom tune you have,running higher than stock boost. You can email Mark Swinehart,the registrar--> comregistrar@comcast.net and let him know.
Glad to see you are coming aboard the COM express!
Mark
All ST and SS cars must run stock boost pressure and boost control. Otherwise you're bumped to SP or P.
