FireStormGraphix?
FireStormGraphix?
Has anybody used FirestormGraphix for their COM or SCCA car numbers? Their SCCA 1-color Number Kit includes two 13" (2 digit) numbers, two 5.5" numbers, four 4" class designations, and two 2" tall driver's name stickers, all for $25. I asked whether they could change the 13" numbers to 8" (the minimum size according to the COM rule book) and they said to just note it in the Additional Comments field on the order form.
http://www.firestormgraphix.com/vinyl/c ... cts_id/743
If anybody has used them, I'd be interested to hear feedback.
Matt
Matt
2001 Corvette Z06
2005 Pontiac GTO LS2/T56 ST1 #52 (sold)
1970 Corvette LS1/T56 ex-SSGT (sold too)
http://www.kmmotorsports.com
Georgethefierce
we have a local member that does a ton of the graphics on cars around here
www.rallydecals.com
KC will hook you up with exactly what you need.
www.rallydecals.com
J
07 IT7
Angrypork.com
84 RX-7
07 IT7
Angrypork.com
84 RX-7
Thanks for the link George. How well do the magnetic numbers stick? Will they hold on at 140mph at The Glen?
-Matt
-Matt
2001 Corvette Z06
Georgethefierce
Squier Design
I always love www.squierdesign.com. They have packages, and are the cheapest and now they also can do full photographic decals. See the Greased Shadow on their home page. Michael's wife also is an artist and came up with the artwork for my car.
enjoythemusic
Re: FireStormGraphix?
....removed
I have my own vinyl cutting machine and can cut the graphics you need for COM. Just let me know what you need and I'll bring it with me to WGI (assuming you'll be there) or if you're going to an event I wont be at I can mail them.
I typically dont bother with magnetic (tend to come off) but use a special vinyl that is removable and leaves no residue and is very easy to peel off when you're done. Its worked really well for me in the past. Enjoythemusic has used my decals, as mentioned, so ask him if you'd like a reference! Some pics here
I guess I could match the $25 that other guy was charging for a single layer vinyl set to meet COM guidelines, although its less than I'd charge normally. COM special! \:D/
ps - I can also cut almost any graphic from this site - use search field at the bottom: http://www.brandsoftheworld.com/
swinecanfly
- Fast Lapper
[/img]
