HI all ,
Any of you Evo guys/gals got any old rotors kicking about you dont need anymore. I am building a car that is not an EVO and I am thinking about using EVO brakes, hence I want some rotors to test fit.
If you have take off calipers LMK too.
Cheers
Haydn
email me at haydn.taylor@gmail.com
WTB USED (yes used) Evo8 rotors, F&R
Re: WTB USED (yes used) Evo8 rotors, F&R
Is that the same fitment as the STi Brembos? Just wondering.
I dont think they are exactly the same, but probably close. at least for the fronts, the pad shape and bolt pattern are the same. have no clue about the rears. the pad thickness of the evo calipers are thicker than for the sti. some pad mfr's just end up making the thinner (maybe a mm or less) of the 2 and call it a day.
Hayden, I have a couple spare sti fronts that you can use to test fit if you want, lmk. no dice on the calipers unless you want the bbq'd ones off my car
Joe Lu
#24 ST1 STi
#24 ST1 STi
