What COM folks are building...
Re: What COM folks are building...
Post by breakaway500 » Thu Feb 04, 2010 10:13 pm
It would be nice to see them at COM in any class.. :wink:
John F
Post by John F » Sat Feb 06, 2010 6:50 pm
Absolutely! Pat could use some competition PA :D SPA is too crowded for them, sorry 8)
John F
#167 SA FFR roadster
timmmy
Post by timmmy » Sat Feb 06, 2010 10:57 pm
Unfortunately we wont see any of them at COM, 2 are from too far away, and the TTV8 coupe although it is local isn't caged so cant play :( Its owner has a rather nice URQ that is getting a 700WHP 5cyl 20V though, and that might just get a cage :)
The good news is I will be bringing my car to play in PA, heres an update from todays efforts.
Cage is getting closer to being done
Time for another roll cage update.
Today I did a bunch of cleanup, added in the 2 sill bars and a load of other tubes.
Sill bars in
Next up was the addition of the diagonal in the rear down tubes, and the rear strut tie bar.
This is how all the tubes in a cage should come together above the drivers head
The tube to tube joints are all TIG welded as the cage is 4130, I have been trying to get used to my torch hand controller as using the foot control is a PITA for this stuff. The welds came out OK, could be better but they will certainly do. This shot is right before I added the main hoop diagonal.
Mai hoop diagonal interface to the spider is a bit complex, I used the fancy pin gauges to get this right.
Here is the spider with the 7th tube added.
And the bottom of the main hoop diagonal
This is really the bulk of the main cage done. There is still plenty to do on it including adding the harness bar, a couple more rear supports and a bunch of gussets oh and of course the door bars.
Last job of the day was to prep for an initial weight measurement tomorrow, I have arranged to borrow some race scales so this should be interesting.
To be honest I dont know what to expect the weight to be, or the distribution. I could guess but I am bound to be wrong so I wont publish my guestimate here.
Stock list weight was supposedly 2850lbs. I am guessing stock distribution was something like 60F/40R? (57/43 maybe?) Anyone have measured numbers for a fully complete, stock 4K?
Haydn Taylor
www.motorsport-ht.com
John F
Post by John F » Sun Feb 07, 2010 11:01 am
Nice work!
John F
mossaidis
Post by mossaidis » Tue Feb 16, 2010 8:29 pm
A shop owner and I have decided to build a USRC M1-spec rally car from a '68 Porsche 911 and a RS 2.7L motor. Photos will be attached as they become available:
Kai Noeske
Post by Kai Noeske » Sun Feb 21, 2010 12:00 pm
Here is where Dave and I are at.
For detailed account of brutal shop day injuries, go to:
http://www.roadraceautox.com/showthread.php?t=27894 :lol:
Post by breakaway500 » Sun Feb 21, 2010 12:29 pm
The corner workes will have no trouble identifying you.. :wink: (looking good.. :sunny: )
jrottn
Post by jrottn » Thu Feb 25, 2010 12:08 pm
Have been building this for quite some time now
1982 930 salvage (insurance job)
Car had broken head studs and was stripped of all body panels/doors
Perfect SPA donor car
Now car wears some fiberglass, has a full cage, suspension stuff, and should make some powpow
Hoping for sub 2500 lbs and should make 400+ rwhp at low boost
Hope to complete this car before I am 90 years old
Will try to post pic
john bradshaw
porsche 930rs
SPA #227
Post by eastcoastbumps » Thu Feb 25, 2010 8:11 pm
Kai Noeske wrote:Here is where Dave and I are at.
Is that Tom Hoppe's old car?
Kai Noeske
Post by Kai Noeske » Fri Feb 26, 2010 8:43 am
Sam Ryan's.
timmmy
Post by timmmy » Tue Mar 09, 2010 1:29 pm
A quick update.....
Cage is about done, except for doorbars, and they go in at the very last moment as working in the car with them in place sucks. Cage gussets are all in, Driveshaft is in, seats are in etc
Exhaust mounted and working on downpipes. I hope to have the exhaust finished this coming weekend, except for the tailpipes but thats just fru-fru.
Next up is fuel system setup and coolant lines, and a few other minor things like lugs to support front bodywork frame, then it can get painted and final assembly can begin.
Haydn Taylor
Post by WillM » Tue Mar 09, 2010 8:22 pm
timmmy wrote:A quick update.....
You had time to carve your initials into the rollcage's gussets? Man, no wonder you're not done yet! :lol:
Nice work..!
timmmy
Post by timmmy » Wed Mar 10, 2010 12:04 am
The joy of waterjet cutting :)
Haydn Taylor
Kai Noeske
Post by Kai Noeske » Wed Mar 31, 2010 9:20 pm
Here she is... ready to go... :D !!!
Kai Noeske
Post by Kai Noeske » Wed Mar 31, 2010 9:24 pm
Inside:
...and her butt: (Dave put the pink 'R' on to announce my Rookieness):
