Unequal pad wear
Re: Unequal pad wear
Post by Chrispy » Sat Jul 09, 2011 10:11 am
Jeff, the last time I saw aggressive pad taper it was because the pads were too soft. Are you using the same compound that you used to? These are the stock single piston calipers I presume?
Post by 6PAK72 » Sun Jul 10, 2011 5:39 pm
STOCK 1.6 NA calipers, Dtc60 front, 30 rear, new master ( ! ) thoroughly bled. Stock 1.6 rotors.
Post by WillM » Mon Jul 11, 2011 2:40 pm
6PAK72 wrote:STOCK 1.6 NA calipers, Dtc60 front, 30 rear, new master ( ! ) thoroughly bled. Stock 1.6 rotors.
Carbotech pads + stock Miata calipers + driving faster = pad taper.
Didn't Liz drop some significant time and set a personal best at this event? Didn't you also do the same, and win ST4?
It isn't so much that the equipment changed...
BTW, I always had crazy pad taper with the Carbotechs. Stepping up to XP12/XP10 F/R from XP10/XP8 F/R helped a little bit.
To get better life, and regain pedal feel, swap the pads around every or every-other day. This will even out the wear.
Brake cooling ducts should help a bit too. Not sure if you have 'em, or if they are legal for your class.
Post by TroyV » Mon Jul 11, 2011 2:49 pm
That's weird. I don't get that kind of taper at all, and have been running XP10/8 since I got the car.
subsonic
Post by subsonic » Mon Jul 11, 2011 2:50 pm
breakaway500 wrote:I have noticed over the years since the introduction of 4 channel ABS,pad wear on cars to be uneven,particularly on cars that are driven hard. I believe this to be the direct result of the abs system being able to control the application pressure on each caliper individually of the others..therefore the unequal wear to the pads from corner to corner.Unless you find something mechanically wrong with a caliper,as in sticking pistons or misalignment of the pad carrier,I would say not to worry. :wink: :sunny:
Yes - ABS and plenty of trail braking will do that with heavy cars. I've learned to lived with it, I swap the pads around (just like tires) in an attempt to prolong their life. I'd not worry about it.
As for ABS and getting 'both feet in' - I am with Nate on this one: disable it or run the risk it will turn your car into wall when you get ' both feet in'.
#217 SPB
Post by Chrispy » Mon Jul 11, 2011 3:05 pm
TroyV wrote:That's weird. I don't get that kind of taper at all, and have been running XP10/8 since I got the car.
Do you actually use the brakes in that car? Haven't you had the same pads in there for like 3 years? :)
Post by TroyV » Mon Jul 11, 2011 3:50 pm
I just put in my 4th set of front pads, and 2nd set of rear pads in....well.....3.5 seasons and probably close to 10k track miles. I run those suckers straight down to around a few mm off of the plates though.
Post by WillM » Mon Jul 11, 2011 3:53 pm
I knew I shouldn't have sold that car.
Post by TroyV » Tue Jul 12, 2011 1:36 pm
Too late......besides...you got good money for it. :)
Post by 6PAK72 » Tue Jul 12, 2011 2:17 pm
@Will, no complaints, just a new condition.
I'm paying close attention to any change right now....
Post by CP » Thu Jul 14, 2011 10:35 am
Are you using the factory rattle clips which allow the pads to slide on the caliper bracket? If not then your pads could be moving around excessively. I hit the clips with a brass/wire brush between events to keep the pads sliding freely on them. I also re-lube all my slide pins between race weekends because brakes are important.
boltonite
Post by boltonite » Thu Jul 14, 2011 11:24 am
Regarding the original post, might want to examine the RF wheel bearing/hub, the pad wear can be an early warning sign of impending failure. -FF
Post by Chrispy » Thu Jul 14, 2011 12:06 pm
Thanks I'll check that out. I gave it a quick check while I was swapping the pads out but I will take a closer inspection.
Post by CP » Thu Jul 14, 2011 4:28 pm
Any fore/aft or side/side play in the wheel (jacked up) means the front hub is toast. If you drive on it, the wheel will eventually part ways with the rest of the vehicle. A popular mod is to re-pack front hubs with a moly grease like Redline CV2. I've got a hub on order from Mazdaspeed and I'll be tearing it apart for a grease job as soon as it arrives.
Post by Chrispy » Thu Jul 14, 2011 5:12 pm
How do you disassemble these modern hubs? Do you just use a press like you would for the older hubs with serviceable bearings?
