Brake pads for heavy turds
Re: Brake pads for heavy turds
I ended up with Kuhmo V730 tires and Hawk DTC-60 pads. Thank you for your very helpful comments. Now on to rotor cooling with some factory naca ducts below the FBC and some ducting to make it more effective.
Am I going to have a problem running sessions but no time trial with an unclassed car? I don’t see my old wagon listed on the Touring list and don’t plan to run any time trials, so classification is somewhat irrelevant in my case.
No, that should be fine. A steward can class the car at the event if you change your mind on doing the TT down the road.
Brandon Ganem
#105 Mazda RX8
#105 Mazda RX8
