Yep, I also got 6.33 using the numbers you provided -- the alternate power I got was 418.6.
As it stands with the 418.6 hp Option B calculated power, you'd have to get to a competition weight of 2721 lbs to squeak into Super A.
Car: 2470 lbs
You: 180 lbs
Helmet and HANS: 6 lbs+
_____________
2656 lbs
If you wanted to run SA, you'd have to add 65 pounds of ballast. Was the 2470 pound weight with a full tank of gas? Alternately, you could reduce your rev limiter to 7614 RPM and forget about putting ballast in. By doing so, you'd being the Option B power down to 408.6, and the resulting weight to power ratio to 6.5.
You might be able to get a lower power using Option A. What kind of dyno were your power runs made on? The rules state that you can take a 7% decrease for a correction factor on an AWD car if you used a Dynojet or Dynapack system.
Also, "Power" is defined as
“Power” = 2/3 wheel horsepower + 1/3 wheel torque
If you have a medium-ish amount of rwtq you might be able to get the power figure used in the calculation a smidge lower, especially if you took the numbers on a Dynojet or Dynapack.
Mitsubishi Evo (prepared something.. something)
Re: Mitsubishi Evo (prepared something.. something)
-Fred
#242 T40 BMW E30
#242 T40 BMW E30
All signed up! I'm just going to run Super Duper class so there's no objections from anyone.
Alex Grabau
BMW E30 M3 FIA GR.H
BMW E30 M3 FIA GR.H
Alex SU is the right class to run. You don't have to worry about horse power, dyno sheets, torque, weight, etc. All you have to do is have a roll bar, driving suite, window net (or arm restraints), harness, and helmet. It's a run what you brung class. Have fun, I wish I could be there with you.
